WTB == Rear Differential 4.444 ASAP!
I need a rear differential as soon as possible. It has to be 4.444 gear ratio and LSD is definitely preferred.
Gotta get a good 4.444 diff before the 20th so I can drive my car to the West Coast Subaru Show.
Re: WTB == Rear Differential 4.444 ASAP!
Is it possible to buy an open 4.444 diff and put my LSD unit into it?
EJ KILLA
Post by EJ KILLA »
you should check pull a parts, i pulled a 4.44 trans from a 96 outback for 65$
yes, couple things to think about when swapping, Grinding and shimming:
http://www.rs25.com/forums/f105/t99509- ... -vlsd.html
Thanks for the infos.
Bump still looking for a 4.444 rear diff. No luck so far.
