Converting CABLE trans to HYDRAULIC. Easy to do?
I blew up my n/a 00 legacy transmission, and they are hard to come by. Cable transmissions on the other hand are a dime a dozen at my junk yard. So, question is, how easy/hard is it to convert? I can grab the fork off my trans. Only other thing i noticed is the slave cylinder mounting holes might not be there on a cable trans. Any links or help appreciated.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Re: Converting CABLE trans to HYDRAULIC. Easy to do?
You will have to move the pivot ball for clutch fork. You'll have to tap the other boss and move the pivot ball. If you look at both transmissions, you should see what I'm talking about.
thank you Josh. So it is possible then. I just needed to know before i bough one. Is it hard to do btw?
I forgot to mention that the slave is bolted on top of the bellhousing not on the side like on my turbo trans. So ur answere was for a n/a to n/a conversion correct?Legacy777 wrote:You will have to move the pivot ball for clutch fork. You'll have to tap the other boss and move the pivot ball. If you look at both transmissions, you should see what I'm talking about.
That is correct.
The mounting for the slave should be there. At worse, you may have to tap and/or drill and tap the hole.
