I have some EJ22t parts from a build that I did. I am a nOOb here but you can check my trader rating on Nasioc before you buy
EJ22t crank and rods. Great shape! $100 shipped, $90 picked up
Damaged EJ22t block. #4 cylinder bore is scratched and will require sleeving to fix. All other machine work is fresh $300 picked up or $350 shipped
The engine was being tuned and literally had 12 miles on it when a circlip popped out and the wrist pin chewed the block.
I also I have a set of 4 Legacy turbo wheels with mis-matched tires. 3 are in good shape and 1 is damaged but functional $150 picked up
Pics:
Crank and Rods
Block
The damage to #4
Thanks for looking!
