heya,
im from new zealand currently trying to do a single turbo conversion on a 1997 Bd5 RSB Twin turbo anyways
im struggling to find any hard info on the correct oil feed sizes for this turbo (standard early wrx sti TD05h 16G with modifed straight inlet)
i need to know the correct size on the head end in the bango which goes to the oil feed line and on the bango in CHRA (turbo end)
any help would be greatly appreciated
Td05h 16g oil feed sizes bango bolt
Re: Td05h 16g oil feed sizes bango bolt
Here's a kit:
http://cgi.ebay.com/ebaymotors/XAVIAR-T ... ccessories
Oil feed and return banjo bolt size is M14 x P1.5mm Banjo Bolt.
are you sure? the 2 larger ones are the water supply and return bangos
http://cgi.ebay.com/ebaymotors/Turbo-Oi ... 588928a4ed
is this not the right size? you can see the 2 bango bolts at the bottom of the picture the large 1 is from the head which has a larger restrictor hole and the one to the right is for the turbo which has the smaller restrictor hole
No that's not the right kit. That one has M12 banjo bolts and those are too small. The one I listed is the right kit. I just bought one last month and used it on my Subaru TD05 16g turbo.
