sti swap?
joelegacy
sti swap?
Post by joelegacy »
hi everyone, i am new to this fourm for now i have one of the greatests subarus ever built lol (93 legacy ss 5spd) so i was wondering if someone can point me in the right direction, i obtained a 04 sti engine, harness, ecu, pedals, fuel pumps, and or misc stuff and was wondering what are my options for put the engine int the car or creating a hybrid swap with the ej22t motor? much apperciated for any info on this
Re: sti swap?
Welcome to the BBS.
If you've got the time, knowledge, patience, and money to swap in the STi engine, it should be a pretty killer setup. Some things to note are you will likely have to rewire the entire car to some extent. Also the ECU location is different, and there are additional sensors for the STi.
Other things to keep in mind is the drivetrain. The stock drivetrain will only likely hold up for so long.
