Couple questions about 92 legacy SS
asotwavb
Post by asotwavb »
Vehicle has EJ20g from a first generation Legacy RS. What are my options to monitor injector duty cycle? I already have a wideband to install, but i would like something to monitor injector duty % without going the option of standalone.
1992 Legacy Sport
CAV3MAN227
Re: Couple questions about 92 legacy SS
Post by CAV3MAN227 »
-Apexi AVC-R might be an option!
-Joe
PhyrraM
Post by PhyrraM »
Monitor or modify?
If you just want to monitor the duty cycle, I think you can get it using the Subaru Select monitor or equivalent software. Google up SSM and VWRX and follow the trail. There is info out there.
What I would do is to get a digital multimeter that can measure duty cycle. Tap that into one of your injectors @ the ECU pins. Not as neat as datalogging to a laptop, but just as effective if all you want to see is how close you are to maxing out.
asotwavb
Post by asotwavb »
I've been looking into the AVCR, and that may be the option i go with.
PhyrraM,
Thanks for your input, i thought about the multimeter but i want something a little more "cool" :roll:
I'm not too interested in adding fuel just yet. I like the way the car performs with the stock fuel system and turbocharger. How much boost are these stock ej20g injectors good for on my vf11? I beilive they are grey tops, and i am still running the factory air to water intercooler.
-William
1992 Legacy Sport
asotwavb
Post by asotwavb »
How does a factory 2002-2003 WRX OEM turbocharger line up? I know it needs to have a cast 90 degee angle, but how do the oil and coolant lines fit?
1992 Legacy Sport
