parts that have been replaced:
starter
front seals
timing belt
spark plugs & wires
intake manifold gaskets
throttle body gasket
front and rear brake pads
Transmission flush
transmission filter
keyless intree system
valve cover gaskets
newer rear suspention from a 92 40k miles
new aftermarket radio speakers
stock radio with origenal cd player
the bad:
driver window switch broke and cant roll down driverside window
the valve covers leak, need RTV to stop the leak
both front axles need replacing but will last awhile just make noise when turning
sunroof leaked but that was fixed with RTV
the trunk leaks alittle
damage to front passanger side and rear driverside rear conner pannel
the cd player works but the wire for the antanna broke so you cant get raido statons
