wrx clutch parts
__TT__
wrx clutch parts
Post by __TT__ »
so ill be revamping the clutch system in the 94 tw. are all these parts interchangable.
master cylinder
slave cylinder
fly wheel and clutch
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: wrx clutch parts
Yes they should be.
The only thing that may be different is the fitting where the clutch master and/or cylinder hooks up. Not sure if the WRX parts use a banjo style fitting or compression flare fitting.
wtdash
Post by wtdash »
Make sure you get the correct year FW. The 06+ stuff is PUSH-style, as the original SS used a PULL. But since yours is a swap.....you probably already knew that.
Td
P.s. JC - I'm not following you around the BBS!
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
SiCkSTi04
Post by SiCkSTi04 »
Legacy777 wrote:Yes they should be.
it uses the flare fitting on the MC side and banjo on the SC. I want this as i cant find a SS line for the stock clutch line which uses the banjo's on both sides :(
