wrx clutch parts
Posted: Mon Sep 06, 2010 6:02 pm
by __TT__
so ill be revamping the clutch system in the 94 tw. are all these parts interchangable.
master cylinder
slave cylinder
fly wheel and clutch
Re: wrx clutch parts
Posted: Mon Sep 06, 2010 6:37 pm
Yes they should be.
The only thing that may be different is the fitting where the clutch master and/or cylinder hooks up. Not sure if the WRX parts use a banjo style fitting or compression flare fitting.
Posted: Tue Sep 07, 2010 10:11 pm
by wtdash
Make sure you get the correct year FW. The 06+ stuff is PUSH-style, as the original SS used a PULL. But since yours is a swap.....you probably already knew that.
Td
P.s. JC - I'm not following you around the BBS!
Posted: Tue Sep 07, 2010 11:24 pm
by SiCkSTi04
Legacy777 wrote:Yes they should be.
it uses the flare fitting on the MC side and banjo on the SC. I want this as i cant find a SS line for the stock clutch line which uses the banjo's on both sides
