Car stalling when cold
logan9691
Post by logan9691 »
So when my car is cold (first start up, or sitting outside for a long period of time) it will stall when I go a short distance and then put the clutch in when I stop (driving through a parking lot, ect.). I have no idea why it is doing this and it is starting to get really annoying. Anyone have any ideas?
-Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: Car stalling when cold
what kind of BOV are you running? Atmospheric? i know that's what my issue is right now...
Does the car run fine when it's warmed up? How old is the coolant temp sensor? Do you have any problems starting the car when cold?
logan9691
Post by logan9691 »
The car runs fine once it is warmed up, I have never changed the coolant temp sensor since I've owned the car (only a year) but not sure if it has ever been changed. It starts fine when it's cold.
Legacy777 wrote:Does the car run fine when it's warmed up? How old is the coolant temp sensor? Do you have any problems starting the car when cold?
Have you checked for intake leaks? Also, what cj91legss mentioned.....are you running any kind of aftermarket BOV?
yeah an atmospheric/hybrid can really mess up your idle/starting/stopping at a light
