I have a bunch of parts for sale. You will get everything pictured for $75 . Just need this stuff gone. Shipping weight is included so that you can calculate. I use UPS ground so no shipping to PO boxes. My zip is 60069. I have not tested these items but they are cheap enough.
My shipping estimate for everything would be between $60 and $150 depending on your location.
Turbo intake parts with release valve.
2 Flywheels
Complete intake .
3 Alternators.
2 Water Crossover Pipes.
2 Power Steering Units
Bunch of Pulleys
2 Water Pumps
3 Timing Tensioners
2 Oil Pumps.
3 Prong Charcoal Canister
STI Top mount Air-Air Intercooler
Pair Cylinder Heads $30.
Final EJ22T Parts Sale: $75 plus shipping for everything!
Need one part from the intake picture the bottom left on the picture. 90 elbow with vacuum holes
91 Legacy SS 440s, vf39, FMIC, LSD, Revtronix Stage 2, MSD Coil
Re: Final EJ22T Parts Sale: $75 plus shipping for everything
I'm in need of this part don't know what its called so if you know that let me know also I don't see any shipping weights
It's called the "F Pipe".
are you willing to sell the f-pipe and what about that little plastic piece above it that goes into the intake both of these are broke on my car and I have them rigged up for the time being
interested in just the intake piece that attaches to the throttle body, with bypass valve.
intrested.... i need a flywheel
Does the STI topmount come with y pipe and all necessary parts for install? Interested.
BatLegacy
BatLegacy
Ill take the STI topmount, PM me
