recalls
recalls
so i took my 90 into Subaru today to get an oil change and i was informed that i had 2 recalls for my vehicle. funny thing is that apparently these came out in 1990 and im just now found out. however this is the first time i have taken my car to Subaru for work. the rcall was for the screws that hold the door latches and the defroster door or something like. the dealership is going to fix the for free they just need the parts. apparently the concern was over time the screws would back themselves out and keep the door from latching causing the seats not to operate unless you did the manual way. didn't know there was one. the recall for the defroster could keep it from opereating in which cause you wouldnt be able to deforst as effectivly. ended up with an full synthetic oil change and tire rotation for $58, not bad. then they told me brake lights were out and i asked how much for that and she said with parts and labor it would be like $55
. i said no thankyou i will do that myself. has anyone heard of this recall?
Re: recalls
Odd the TSB database doesn't have either of those listed for your car.
'11 WRX Limited
'94 TW | R.I.P.
