so,
i'm hoping someone has a pair of rear top hats (90-91) lying around from a group N install or the likes. i found a respectable deal on some STI springs and was considering replacing my aging struts. please good condition and reasonable pricing. i'm trying not to spend too much because once i go down that road i end up pricing myself out of doing anything... it's the why buy OEM top hats when group N's are only this much more? why not upgrade to koni yellows and really make it worth the install? finally, i just get to H&R coilovers is where i should be and the GF needs an engagement ring before i need coilovers. you see where this is going, people?
thanks,
david
21701
WTB: 90-91 Rear Top Hats
ckcadavona
Re: WTB: 90-91 Rear Top Hats
bump...I'm looking for the same but I don't care if they are group N or not. As long as they are not rusting. Thanks
i ended up buying them new from subaruparts.com after not being able to source any used take-offs.
best of luck in your search.
sleepyninja
I just did the same
