1993 Legacy radio wiring
Isaac
Post by Isaac »
I recently purchased a 93 legacy without a radio. The radio wiring connectors were snipped, so I have no way of knowing what goes where. I found two different color charts, neither of them were correct.
Edit: I found a third chart, but I do not have some of the listed wires.
http://www.the12volt.com/installbay/ste ... /1980.html
http://en.allexperts.com/q/Audio-System ... ereo-1.htm
Edit: http://www.modifiedlife.com/1993-subaru ... g-diagram/
I am hoping I won't have to get a meter to check each wire individually. Anyone have a correct chart?
Thank you for any help,
Isaac
Re: 1993 Legacy radio wiring
Welcome to the BBS.
These may help.
http://www.surrealmirage.com/vrg3/bcstereo/
This is for a 90 legacy, but should be same
http://main.experiencetherave.com/subar ... iodiag.jpg
