Upgraded brakes from a 03 wrx
Subiel94
Post by Subiel94 »
So my car (94 subaru legacy turbo) has 03 wrx brake calipers. And it doesn't have the abs sensors hooked up. How can I make then sensors for those to work with my car? I'd really like to have abs on my car. I live in Ohio and winter is coming. Abs system is all new to me never had a vehicle with it but I want this car to have it. So if anyone has any ideas about how I could make it work it would be very helpful. It's just my front calipers. And I was told from previous owner they didn't match up so they didn't worry about it. But like I said if you have any idea about this please help me out.
Re: Upgraded brakes from a 03 wrx
The calipers have nothing to do with the ABS system. The ABS sensor plugs into the lower part of the back of the wheel hub, and there's one sensor per wheel.
This thread mentions how to pull up ABS error codes
http://bbs.legacycentral.org/viewtopic.php?f=8&t=882
Perhaps one of the sensors is bad, or the ABS tone ring on the wheel spindle has a broken spot, etc.
Subiel94
Post by Subiel94 »
Yeah I didn't see anywires or anything when I took them off. But thanks for the lead. I'm gonna try and figure it out.
Subiel94
Post by Subiel94 »
Ok I did that. How can I find out which code means what??
Subiel94
Post by Subiel94 »
Thanks once again man. I'll be doing that now. Hopefully just an easy fix. For me
