Impreza clutch
KristianM
Impreza clutch
Post by KristianM »
Hi.
Can i use an impreza clutch and flywheel on my legacy? It's a MY93 turbo with EJ20GN engine. I've passed 300hp and need a stronger clutch.
Florin1
Re: Impreza clutch
Post by Florin1 »
Nope. You have a pull style clutch, and the impreza is push. The flywheel should work though. Unless you're talking about impreza wrx, then it will fit
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
KristianM
Re: Impreza clutch
Post by KristianM »
The imprezas over heres got pullclutch as well. it should fit.. i got the same MT5 trannie as well..
biggreen96
Re: Impreza clutch
Post by biggreen96 »
Yeah it should work.
Re: Impreza clutch
Yeah...as long as they're both turbo "pull" type trans, flywheels, clutches, pp's should be interchangable.
KristianM
Re: Impreza clutch
Post by KristianM »
Well, the clutch is just days away, so i guess i'll see in a few days if it fits or not. It's a stage 2 WRX clutch with a 9lbs flywheel. Dont think i'll be driving down town to much with that clutch :)
