Seemingly simple question
Danny-G
Post by Danny-G »
I,ve been wondering if swapping a wagon ecu with my sedan ecu will get the little bar on the dash to light up with the trunk open, like it does on the wagon when the gate is open
Danny
SLODRIVE
Re: Seemingly simple question
Post by SLODRIVE »
Sorry, it won't work. The door switches/dome lights/indicator lights for the doors don't interface with the ECU.
http://www.slodriveracing.com
-And more!
soundman353
Post by soundman353 »
I don't think so. I took a quick look at the wiring diagram for a 1990, the door switches do not feed into the ecu. You will need some sorta switch and some custom wiring to get that lil light to work.
EDIT opps i didn't refresh.... sorry SLODRIVE for the double answer
Danny-G
Post by Danny-G »
Well dang...I guess its time to get the wiring from a wagon and see if I can make it work some how. Unless anyone has an idea of how to get it to work.
Danny
Apex3
Post by Apex3 »
Do you even have that light on the dash?
If so it should be a fairly easy job, just wire that light to the trunk light.
Danny-G
Post by Danny-G »
Its in the cluster but doesnt function due to having a sedan. And tapping into the trunk light is a really good idea, I don't know why I did'nt think of that.
Danny
BSOD2600
Post by BSOD2600 »
You should look over the wiring diagrams between the wagon and sedan... have fun wiring it all. Not going to be easy or worth it, IMO.
'11 WRX Limited
'94 TW | R.I.P.
The clusters are different between wagons & sedans I believe and don't have the light. If you have a wagon cluster in a sedan, you could probably wire things up so the trunk causes the light to go off.
