Who make a direct replacement that will fit in the stock mounting location?
Brian
SS Brake Lines
SS Brake Lines
1992 Legacy L (AWD )(5MT)[2.5RS Trans] EJ22T Swap in Progress
Re: SS Brake Lines
Goodridge makes a set. Use the ones for GC impreza for a direct fit.
You can also use the ones for the WRX. The only difference is in the mounting bracket to the strut. The WRX ones have a fixed mount that you just zip tie to the strut....no biggy really.
Re: SS Brake Lines
Awesome thanks my brakes feel like shit after driving my brothers WRX!!!
Re: SS Brake Lines
BTW, it's brakes, not breaks
Re: SS Brake Lines
what years of wrx brake hoses work
Re: SS Brake Lines
I believe 02-07 will work, which is before they changed the rear suspension design. The center part will not bolt to the strut and will need to be zip tied.
Re: SS Brake Lines
that part is fine i just wanted to make sure they'd work before i ordered some this week
