WTB: EJ20G or EJ20K turbo reservior tank
I'll come back and post a photo later but I just wanted to get the word out ASAP. I need a reservoir tank / "header tank" / whatever you wanna call it for an EJ20G intake manifold or even one for an EJ20K should work. The inlet on mine is cracked and QuickSteel will only hold up for so long under radiator pressure.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
Re: WTB: EJ20G or EJ20K turbo reservior tank
i have one from a 20G. PM me if still interested... make offer...
-=Suberdave=-
-=Suberdave=-
