So got everything figured out with the over boosting and now I have it set at 10psi but I'm still hitting fuel cut.
Any ideas?
Thank you.
I guess the easy fix is install a FCD.
Fuel cut 10psi?
turbonator
Re: Fuel cut 10psi?
fuel cut defenders are pretty easy to make, i know i made a few and sold them.
dscoobydoo
Re: Fuel cut 10psi?
Your fuel cut will be between 10-12psi depending on a few other atmospheric factors.
IF you want more- then get a FCD- but be careful that you do not overboost.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
