Fuel cut 10psi?
Posted: Sat Oct 30, 2010 3:37 pm
by turbonator
So got everything figured out with the over boosting and now I have it set at 10psi but I'm still hitting fuel cut.
Any ideas?
Thank you.
I guess the easy fix is install a FCD.
Re: Fuel cut 10psi?
Posted: Sat Oct 30, 2010 3:42 pm
by cj91legss
fuel cut defenders are pretty easy to make, i know i made a few and sold them.
Re: Fuel cut 10psi?
Posted: Sun Oct 31, 2010 3:04 pm
by dscoobydoo
Your fuel cut will be between 10-12psi depending on a few other atmospheric factors.
IF you want more- then get a FCD- but be careful that you do not overboost.
