Need help Heater not working
samurai
Post by samurai »
Hi i'm new here and last week i bought a 92 Legacy Sedan 4EAT and the first thing i noticed is that the heater isn't working....or is it the fans? i'm not too sure....i mean the rear defroster seems to work and after a little bit i feel heat but i think it might just be from the engine...i'm not sure...the buttons for the heat and defrost work but when i change the dial's i get nothing...if someone could give me some insite on this it would be helpful or some alternatives....I live in Madison Wi, and i'm gonna nead warmth fast
BSOD2600
Re: Need help Heater not working
Post by BSOD2600 »
Possibly worth looking into: http://bbs.legacycentral.org/viewtopic.php?f=10&t=1142
Do you feel air out of the vents when the fan is on and a button is pushed?
Coolant is always circulating through the heater core, so it's jut a matter of having the selector lever in the correct position to give you heat or outside air. When you move the lever, it should have some resistance and you'll hear a door moving in the HVAC ducts.
'11 WRX Limited
'94 TW | R.I.P.
samurai
Post by samurai »
I feel air but it feels likes it's coming just from the engine...i don't hear anything like air blowing or anything...and when i try to change the fan setting from like 1-4 (or is it 5?) it doesn't do anything...if it's warm tommorrow i might try getting back there but i'm a big man...and don't know exactly where or what to look for..
Directly under the glovebox is the blower motor. It comes out with 3 screws. Remove the glovebox and it's very easy to take out. You could see if it's getting power.
samurai
Post by samurai »
cool cool....thank you
samurai
Post by samurai »
I found a heater core for a 97 outback and was wondering if it would fit in my 92
I would have my doubts it would work. It may, but I'd be rather skeptical
samurai
Post by samurai »
me too looking at some pics it looks like it might but then again i'm not sure does anyone have any pics of the two?
