Looking for a pedal assembly to complete my manual trans swap, I am swapping in a hydraulic trans and have the bits for that, but wondering would a wrx pedal assembly work, I have found a few but don't want to pull the trigger until i know it will work. If a wrx on will work is there any years that would work better then others???
Thanks in advance
Greg
Pedal Assembly for Manual trans
04 STI (summer car)
93 Legacy T Wagon (soon to be winter car if i get the transmission fixed)
96 OB (winter car until girlfriend took it over?)
Re: Pedal Assembly for Manual trans
wrx will work, or a 96-99 outback/lgt set will work also. The newer legacy stuff my work but i cannot confirm that.
*sold*
*sold*
USDM WRX stuff needs a few minor mods. Some holes are just a bit different.
'91-'94 Legacy turbo will bolt in. I *believe* the '96-'99 Legacies with EJ25s will also bolt in. I would also *guess* that any GC/GF style Impreza with a hydraulic clutch (2.5RS) will bolt in.
I have had better luck finding wrx pedals that's my only problem, so I think that im going to pull the trigger and just get them, if I have to do some modification it wont be a good deal, thanks again!
04 STI (summer car)
