Water is going into the light cover that says "Legacy" on the
trunk... i was wondering how i remove that and clean out all the crap
inside with the water, then use silicone to reseal that part so no
more water go in again...
Removing the plastic light cover in trunk lid
Josh Colombo
There should be small bolts on the back side of the trunk lid that hold that plastic piece on. You should be able to just take those off and it should come off..........notice there are alot of shoulds in there....hope it's that easy.
-----Original Message-----
Sent: Sat 3/3/2001 5:55 PM
Cc:
Subject: [BC-BFLegacyWorks] Removing the plastic light cover in trunk lid
Cc:
Ricky
thanks.. i see those bolts.. i will try to take those off and see
what happens!
hold
and it
what happens!
hold
and it
