I Need some new tires
92wagon
Post by 92wagon »
Hi all,
Looking for two sets of 205/55/16.
The first set I'm looking for is an all season set.
The second set I'm looking for is a summer set.
I don't want to spend over 400$ a set if I can help it. and I'm looking to buy new not used.
So my question is... What would you recommend?? What have you had that you have liked, good tread wear, etc......
thanks for your input!
Ryan
94LegWagon
Re: I Need some new tires
Post by 94LegWagon »
$400 will get you a decent set of all seasons or summers.
Check tirerack.com
http://www.tirerack.com/tires/TireSearc ... iameter=16
94 Legacy Wagon N/A 5mt AWD
I'd recommend 50 series for the summers. I've had good luck w/ Kumho's.
I second tirerack. Even with shipping, they're usually cheaper than local places, the selection is better, and they have reviews on the site.
originalcyn
Post by originalcyn »
Tirerack is nice and very helpful (ask for Luke), but if you're in an area that has a discount tire company they'll match the price of tirerack. I went with tire rack on the last set. Price worked about about the same as the B&M because i had to get them balanced and mounted and all that jazz. It's 125 approximately for mounting and balancing at all the places i called. So 84 dollars per tire (general uhp) + shipping (48) + the warranty (40) + mounting and balancing (125). I think in the end it ended up being 30 dollars cheaper than just going to a B&M place, and that was without price matching first. If you can't find the tire you want at a tire shop, definitely go to tirerack. but if you can, see if they'll price match it. it's much more convenient, and you don't have to send in your invoices for repair if you get the warranty from tire rack, and the tire shop will be more willing to do small things for your tires, flat repair re-balancing rotating, etc.
As far as tires, i have generals now. they're ok, but i'm not sure if i liked them as much as the falkiens i had. Supposedly they have a longer mileage life, and they're 33% cheaper. But i liked the stickiness of my last set of falkiens.
Kijan
1993 Legacy LS | PBM 227
