Ej22t swap into a 1997 subaru impreza, need aem fic map
EJ22TKING
Post by EJ22TKING »
I have a 1997 subaru impreza and I am putting in a ej22t drive terrain with a td04 turbo and 2007 wrx intercooler. I have the motor in the car, and I put the wiring harness on from the n/a motor. Since I am running the n/a wiring harness I am running into timing problems at around 3500 rpm, so I decided to run a aem piggyback, I need a map for the aem fic for my impreza to at least get it started, does anyone have one they could send?
n2x4
Re: Ej22t swap into a 1997 subaru impreza, need aem fic map
Post by n2x4 »
Timing problems? What ECU were you running?
SUBARUEHS Racing
