Where to find shop manual to rebuild transmission
subbawho
Post by subbawho »
So I'm in the process of rebuilding my transmission but I need a little bit more info. I was wondering if anyone knew of a place where I can get a shop manual or a PDF of some sort. I'm mostly curious about the measurements I have to make for the differential in the trans. Thanks guys
Re: Where to find shop manual to rebuild transmission
http://www.bbs.legacycentral.org/viewto ... 12&t=14485
Check out the Liberty manual, section 3. Even though it's an overseas manual, the drivetrain info should be the same.
