I am selling a recently (less than 700 miles) rebuilt Ultra-high performance subaru 4eat transmission.
The transmission has the following:
WRX input shaft mod to use the stronger more durable phase2 4eat torque converters
Billet 2-4 brake servo assy.
Wide 2-4 brake band with performance friction material
Froward Clutch is upgraded to 7 frictions
High Clutch is upgraded to 6 high energy frictions and kolene coated steels
Transfer Clutch is upgraded to 7 frictions
Valvebody is modified with a transgo HD-2 kit with custom hole sizes.
3.90 gear ratio
The input shaft, front ring and pinion, and output shaft are all cryo treated.
This transmission was built by me for my car, but i have decided to change things a bit so i wont need this transmission anymore.
The performance parts were developed by the same company that developed rigoli's transmissions. This transmission has the clutch capacity for a 1000whp. But it does not have line pressure and flow of a manual valve body. It also lacks reinforced planetary gearsets that are required at that power level.
It will work in any 3.90 ratio legacy. plug and play
It includes:
1 4eat Transmission
1 WRX stock stall torque converter (rebuilt)
1 WRX Flexplate assy.
Price $4500 firm no core needed
Shipping will be truck freight from 56387
I also have a AP-Racing Sure-Trac R160 rear diff assy. 3.90 ratio $950 shipped
Thanks for looking
For Sale: 750HP capable 4EAT $4500 Sure-Trac R160 3.90 $950
93 Legacy Sport Sedan, Eagle/Wiesco EJ22T DOHC, GT3782vnt turbo at 28psi, Hydra Nemisis 2.6, RC1200cc injectors,
Built 4EAT. AP-racing Sure-trac R160. Brembo GT BBK. JDM Legacy B4 Bilstein struts w/ground control coilovers.
VNT FTW
VNT FTW
