What you would still need 2 coolant T's to for the feed and return coolant lines on turbo. A way to return the turbo oil aka a welded on adapter on your oil pan. Either modify your stock fuel injectors or get some new ones. To notch your cross member or get a turbo one. Re tap were your oil pressure sensor to 1/8npt and a small peace of m to m 1/8npt pipe. Also on this kit you do not need an intercooler cause the water meth injection will cool the air down just fine. Think about it you could turbo you BC or BF in a weekend!
I am asking 600$ OBO. Those of you who have bought these peaces and parts separately know you would spend a lot more. I take pay pal were I would ask you to add 3% to cover the pay pal fees. I would be more than willing to ship it for another 60$ to the lower 48 or you more than willing to pick up in Akron, Ohio.
