Connecting rod question/??
RckyMtnLegacy
Post by RckyMtnLegacy »
I am finally putting my car back together. I will have lots of pics soon (hope to have a build journal too). My question is what is the difference between these two rods:
The one one right is from my 1993 turbo sedan auto. block with a spun sleeve, has a 2 on the shaft and on the side ATNTN45 is etched
The left one is from a block I bought from a sports import yard which had a bent rod but block checked out great. Has a 65- on the shaft and AHUHU44 etched in it.
Just curious thanks.
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
Re: Connecting rod question/??
I'd guess that your one on the left is from an EJ25x motor. You'd need the matching crank for it to work. The n/a rods can take some abuse but aren't nearly as strong as Turbo rods, especially ej257 ones.
RckyMtnLegacy
The block from the yard is a an ej22t also though. I was just seeing if there was a difference because of the markings
They should be the same. I believe the etchings are just a way to make sure the end caps and rods are matched up properly if separated.
BTW, the rods on the turbo and non-turbo are identical....same part #.
RckyMtnLegacy
Good to know
So they are the same length and the pin-holes are the same size? Whoops the picture put me way off. Sorry. :smt053
RckyMtnLegacy
Ya same size. Sorry I noticed that too. Its because they are on my shop manual on different pages so they are not level
