help with a 93 wagon
captin hook
Post by captin hook »
Just bought a 93 legacy wagon auto that cranks but wont start. Geting fuel and spark. going to check timing and codes this weekend but my moneys on the crankshaft position sensor. Any ideas? so if ya gota known working one let me know what you want for it and will get the ball moving.so what year can i use 90 to 94 2.2's? feel free to post pm or email me.
thanks guys/girls ahead of time
this site is the bees knees!
i can be reached at
codyhook28@gmail.com or on here.
magicmike
Re: help with a 93 wagon
Post by magicmike »
most likely could be the timing belt is broken. Does it sound like the starter is cranking a lot faster than it should sound?
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
soobrdad02
Post by soobrdad02 »
I was having similar issues lately (starter sounded like it was going bad, no-start conditions) that were quickly solved when the cam sensor was replaced. Definitely check the state of your timing belt though.
"All four wheels spin? Huh, that's AWD..."
*1991 Legacy wagon, 4EAT, n/a*
*1966 Chevrolet C-10 pick-'em-up*
captin hook
timing belt is good. starter sounds normal not fast like a broken belt thinking it might have jumper a tooth maybe.
Check the codes before doing much of anything else. That should pin point a cam or crank sensor issue.
Aerotech
Post by Aerotech »
I'm having the same issue with mine, cranks slowly like it's fighting itself. Happened out of nowhere, parked it one night it's ran great, next morning, nothing. I thought for sure the belt skipped.
I pulled the timing cover, but everything lines up perfectly, tensioner's good, etc. New belt last year. Guess I need to dig out my spare cam & crank sensors, God knows where I buried them... I pulled the battery before I remembered to read the codes. :roll:
Jerry
captin hook
Re: help with a 93 wagon update
Well got her home and checked the cel NO codes so off come the t belt covers and what do i find? driver side cam is .5 to 1 tooth off so game plane for today is to retime and see if it works. thanks for all the input guys it does really help.
captin hook
retimed cam/crank sensor cleaned and one running car! thanks for all the help/ideas
