"Part Out" 1990 Legacy
S/B Iimports
Ive got a 1990 Legacy that has recently died. The engine is from a 96 Legacy but is a wreck. Unless you want to rebuild it or pick it for parts. It has a 5-speed tranny which isn't the best but its not the worst either. The body is still good with little rust on the body. If it were not for the engine it would still be drivable. But not a winter car. Brrrrrrrrrrrr. its cold in that thing. Give me a call and we'll talk. 207-322-0229
Re: "Part Out" 1990 Legacy
Location?
What happened to the motor? Is the shortblock still good? How 'bout the body? Fenders in good shape? What color? Do you like answering questions?
Area code leads me to believe he's in Maine.
S/B Iimports
Im in Stockton Springs ME. The motor failed due to a blown head gasket and it flooded. If you want To tear it apart and fix be my guest. The body is it good shape for the year, very little rust. Most of the seals round the doors and windshield are cracked tho. Would make a great rally car if you got it running.
S/B Iimports
oh ya its High Tech Red.
