I put this together after reading quite a bit about the coffee can and other modifications.
it works well and now I can hear that little turbo! took about 20 min and about $40.
the vacuum line kit was invaluable. it made the whole thing easy.
That's kind of a continuing discussion of debate. What some open air filters can cause increased turbulance before the MAF sensor, which can cause issues with the ECU's ability to measure the amount of air going into the engine. The stock airbox does a better job at reducing turbulant air across the MAF.
Some have reported loss of torque when going away from the stock air box. Other item of possible issue is over-oiling of filters, and the oil mist can cause fouling and damage to the MAF sensor.
FWIW, I had a cone filter for several years and decided to go back to the stock airbox and add an additional inlet tube to the bottom portion of the airbox.
You're most likely not going to get any real evidence either way on the internet or anywhere else for that matter on which is better; cone filter vs stock airbox. But the way I see it is, the stock air filter filters finer particles from the air than those cone filters. The oiling of the filter is crucial and a lot of people either don't do it at all or over-do it to the point where it's getting on the MAF element and misreading or damaging it.
Why put a cone filter in your engine bay anyways? Save a little money on replacing a cheap OEM filter? Besides the stock airbox was designed with the MAF in mind and to bring in cool air unlike placing a cone filter in your hot engine bay. I've never seen any evidence of an increase in power using a cone filter. Unless of course, you believe that crap that K&N publishes in tuner magazines.
You can take cold air with the air box by removing the snorkel and running a hose to an external intake.
Oy, I guess I'll post this again.
I just reinstalled all the stock air intake pipes, bends, boxes and crap when I swapped engines. It was my first time actually looking at the route of the air flow. I have to think there would be a better way than the stock pipes to bring air into the engine. The loopty loop box in the fender is crazy (is that the snorkel), and doesn't look like it helps the flow in any way. It looks like it's main purpose is built to be water ingestion safe. Cool air yes, but flow characteristics?
Also never had a problem with water. Ramming snow banks will compact snow into it and the engine will stumble a little, but not really be a problem. 20 seconds with a pen or something clears it anyway. More power? Butt dyno says so, and the car was fast for a 2.2 N/A, but how much, if anything the intake contributed, I don't know. What it did do is help keep power more consistent instead of dropping off in hot weather.
