F You Knock Sensor
AfRoDeSiAk36
F You Knock Sensor
Post by AfRoDeSiAk36 »
What a pain in the dick it was replacing it....two extensions, a magnet and high frustration level...no wonder Haynes suggests the intake manifold be removed for replacement...but glad I did it, the old one had an 1/8 inch crack surrounding the part that bolts to the engine...although my check engine light had been intermittent for it for a while now, that light should not come on at all for it unless I F'ed something up
1991 Subaru Legacy 4 Door Sedan 2.2 L Turbo 5SpMT
speedmaxx
Re: F You Knock Sensor
Post by speedmaxx »
I changed mine a whille back it also had a huge crack in it, I guess they get brittle over the years.
Pulling the intake manifold is a much bigger pain then just replacing the sensor, the Haynes manual sucks at times
93 legacy l
to much to list....
Florin1
Post by Florin1 »
I swapped mine out in 5 minutes. Wasn't hard at all... I went right by the throttle body, 1 extension, and one of those wobbly/bendy adapters.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
tahiti350
Post by tahiti350 »
I changed the one on my daughters car took about 5 minutes t get it out (I dropped it and had to chase it), and about 3 minutes to put back in... same as above, swivel socket, and one extension....
I relocated mine to the front of the block :)
kleinkid
Post by kleinkid »
I just put the one on my '94 on the engine side of the engine/bell housing flange, just above and aft of the stock location.
