I have a 1991 NA that was running just fine. Then all of the sudden it was acting like it wasnt getting enough fuel, bogging down, and lose of power. Also the check engine light came on. I pulled the MAF and cleaned it. After i installed the MAF it would start, get up to about 1500 rpms then die.
Any suggestions?
what i think is a MAF problem
Re: what i think is a MAF problem
Check your codes.
Thats the only thing i havent done yet. It wont stay running long enough from me to get to the shop so i can check my codes.
Welcome! You don't need to take the car anywhere as you can pull the codes yourself. Please read the sticky's for popular help like below.
How to Read Trouble Codes From the ECU
http://www.surrealmirage.com/subaru/engine.html
