ill give you the particulars.
i am in Sault Sainte Marie, Michigan.... better known as the north end of I-75
the SS should make it anywhere in the continental united states, possibly even alaska. so picking it up wont be a problem.
the good:
110,000 original miles.
New Clutch - Friction Master
Rebuilt alternator.
vacuum lines checked and replaced.
pretty clean under body for northern Michigan
all electronics function well (exception of seat belts, which flake out every now and again)
the bad:
Front Shocks have had it.
rear sway bar pass-side mount broken.
exhaust is separated just before the muffler (not that loud)
shifter linkage needs new bushings.
needs the body work finished and paint.
i had planned on keeping this car for the rest of its life.
but dire straits say otherwise
