Exhaust Questions from a noob
timebeach
Post by timebeach »
I got a exhaust that came from a '10 WRX. It has a turbine thing in the middle and then y's out to two cut tips /with no mufflers. My friend is also gonna give me a dp from the same WRX. Will these parts work with my 94 SS? Thanks guys!!
Tim
94 SS 4EAT, Under Construction
95 Eagle Summit DL-Daily Driver
Re: Exhaust Questions from a noob
The new cars are pretty substantially different in terms of exhaust, dual tip vs. our single tip, and how the piping hooks up. I would doubt if it's going to work.
timebeach
Post by timebeach »
I had a feeling that was the case. Should I be looking at the 02-07 WRX's for a cheap upgrade? Thanks Josh.
Tim
The 02-07 are more likely to fit, but they still require modifications. The mid pipe needs to be lengthened as well as the axle back section. The hangers are also different at the back and need to be modified.
Here's the thread where I had an impreza muffler modded to my Legacy.
http://www.bbs.legacycentral.org/viewto ... ?f=4&t=640
