Detailed Engine = Engine Problem
darkcrave
Post by darkcrave »
Ran Perfect
I detailed the engine ( degreaser and water )
not it almost feels like a misfire or no boost...
I took out all the spark plugs and coil, cleaned them, tryed to dry all of the sensors that i could, i dont hear a vac leak
Update* drove it home, figured heat may burn the water off. Feels like a boost issue almost... I was getting power then it would stop and surge couldn't get pass 5,000 rpms. Then I would get power then again no power????
Tune
TMIC
Fuel
Taillight
Florin1
Re: Detailed Engine = Engine Problem
Post by Florin1 »
Give it a few days. I had the same prob. I let the car idle for like an hour or two. It still ran crappy for a few days, but got better and better. Hopefully its that easy, huh?
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
darkcrave
Post by darkcrave »
Florin1 wrote:Give it a few days. I had the same prob. I let the car idle for like an hour or two. It still ran crappy for a few days, but got better and better. Hopefully its that easy, huh?
You called it, runs great this morning. Thanks
Tune
TMIC
Fuel
Taillight
Crashsector
Post by Crashsector »
Sounds a lot like the knock sensor. Mine was cracked and every time I washed the engine I would get the same problem. It's shaped like a donut with a bolt through it, under the intake manifold on the driver's side of the block. Even if the sensor looks ok it may be bad, there was an issue with the wire lead breaking too.
--Andy
2005 Impreza 2.5RS. Traded :(
1991 Legacy L w/1994 EJ22T, 16G, WRX 5MT. Sold :(
1993 Legacy L AWD 5MT, 153k miles and many, many more to go.
2008 Legacy 2.5i Limited
Florin1
Post by Florin1 »
Good to hear. :-)
