xmission problems
gmfm86
xmission problems
Post by gmfm86 »
i have a 94 legacy l manual non turbo. 4th and 5th gear just grind. they use to stay in gear until i let off the accelerator and the car would pop into neutral. when i try to put it in 4th or 5th it grinds then just goes to n. any suggestions? if i need a new xmission which years are capatible?
Re: xmission problems
Welcome to the BBS.
You pretty much need a new transmission or will have to have your current one rebuilt. Any of the non-turbo 90-94 Legacy manual transmissions are a direct swap.
