2005 Legacy GT flywheel in an SS?
I'm wondering if an aftermarket lightweight flywheel for a 2005 Legacy GT (push style tranny) will work in an SS with a 2002-2005 WRX clutch kit?
Florin1
Re: 2005 Legacy GT flywheel in an SS?
Post by Florin1 »
Edited. Figured since it was ej series motor... What do i know, i usually shoot first ask later. :(
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Florin, is there a reason you'd say yes to interchangability between a puch and pull style trans?
Post by entirelyturbo »
Fairly certain they are not interchangeable. Also, the 05-06 Legacy had a dual-mass flywheel, while 07+ went back to the single-mass, and from an experience at work, those only interchange with the right flywheel bolts.
Sent from my HTC Droid Incredible using Tapatalk
*Formerly DerFahrer*
I posted the question on Nasioc as well, and someone said that the pull type have a "stepped" flywheel, which won't allow the clutch kit to be bolted flush to it. Ah well, it was worth a try.
