EJ20 Best turbo to run? TD06 or TD05?
mx4life
Post by mx4life »
I am looking to upgrade. Version 1 Sti ej20, what's the best turbo for it? TD06 maybe?TD05?
Click For My 93
Click For My RHD 97
'93 SS V3 RA/STi EJ20K 4.44 DCCD
'97 RHD Wagon soon to be TT
dscoobydoo
Re: EJ20 Best turbo to run? TD06 or TD05?
Post by dscoobydoo »
To best answer your question, it would be good to know your goals, and any other mods you have. I am guessing you already have a TD05-16G?
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
mx4life
Post by mx4life »
I have whatever is stock on the EJ20. Im looking to spool up quicker and bring my boost up to 17 or 18.
Click For My 93
Click For My RHD 97
mx4life
Post by mx4life »
I guess I will start looking for a 16g or a big 16g. found out a 20g might be pretty laggy with this engine
Click For My 93
Click For My RHD 97
wtdash
Post by wtdash »
Not all EJ20's have/had the same turbo.
I'd suggest you see what you have on there now, as the 16G came on the WRX-STi from approx. '93-'96 when they used the 90° inlet - before they changed to the 'inlet under manifold' setup. It could also be a VF-series turbo, but bigger than the US VF11, of course.
Also, unless you plan on getting a tune (recommended @ 17-18 psi anyway), any bigger turbo will most likely have more lag....it's the nature of the beast.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
stef1825
Post by stef1825 »
mx4life wrote:I am looking to upgrade. Version 1 Sti ej20, what's the best turbo for it? TD06 maybe?TD05?
I'd say HTA68
here ... I'll let you read some good infos
http://forums.nasioc.com/forums/showthr ... ?t=1777309
http://www.importimageracing.com/p/Forc ... x-sti.html
mx4life
Post by mx4life »
:shock: Damn that thing is pricey! Sweet though. When I eventually buy my version 2 at the end of the year, I am going to do a full build on it. That will definitely be a consideration for the turbo I use. I want to aim for 450 HP. Right now its my daily driver and just looking to pep it up a bit more without spending a crap ton of cash
Click For My 93
Click For My RHD 97
