The original plan was just to buy an AWD winter beater/daily driver so I didn't have to rely on my work truck or wife's car while I built my 84 Jetta GLI Coupe. The " Budget " was supposed to be $2000 inc. any repairs that needed to make it roadworthy. Since I had limited myself to AWD, there was only about 4 cars that applied in my search, any of which were gonna be tough to find for that cheap. I really wanted a Audi Coupe Quattro since I already own a B5 A4 Avant and the Jetta . Of coarse my other option being a Legacy which I had already previously owned a pearl white 90 5MT SDN. Sadly it met it's demise when a Eagle Talon had ran a red light T-boning me at about 90 km/h. I was not wearing my seat belt therefore I stood still and the car moved it's windsheild into my skull
So after some CL searching I found a mint 92 4EAT SS for $1200, unfortunately on my way out to look at it the first person to see it immediately purchased it
Before :
After :
Current Mod List ( Mar/16/2012 )
Modifications:
Engine
- EJ22T (240 000 Kms)
- RobTune ECU
- TD05-16G
- JDM Greytop 440cc's
- Delta 230 Cams
- Ceramic Coated Exhaust
- 07 WRX TMIC W/ Disected Perrin Y-Pipe
- De-Snorkeled, K&N, Turbo Silencer Delete
- Winton Motors BOV Adapter
- 2 Shiney Ebay Catch Cans
- 3" TBE. Megan DP, Custom No-Cat Mid & Sheep Dog Muffler
- Hallman Pro MBC
- Innovate LC-1 WB Controller
- Walbro 255 Fuel Pump
- Forge 007 Diverter Valve
Chassis
- 05 STI Suspension (Modified to fit)
- 3.90 R160 LSD W/ TIC Bushings
- TWM Performance Short Throw Shifter
- STI Short Shift Kit W/ Kartboy Bushings
- Group N Motor Tranny & Pitch Mounts
- Prodrive Pero-R 17x7 Wheels
- Simmons FR90 16x7.5 3-piece Wheels
- Whiteline F&R 22MM Sway Bars
- JDM Steel 4-Pots
Exterior
- De-Rusted
- Nissan Moss Green ( SOON )
- 07 S206 V-Limited F. Lip ( After Paint )
- Projector Fogs W/ 3000K HID ( After Paint )
Interior
- Recaro Trophy Seats
- Sti Aluminum Shift Bezel
- STI Titanium Shift Knob
- Momo 280mm Team S. Wheel.
- Podi Boost Gauge
- Innovate Oil Pressure / Temp Gauge
So I then replaced the TB,WP, Cam,crank/oil pump & VC seals. Dissasembled,cleaned & tightened the screws on the oil pump. Did the idler & tensioner bearings. Tune-up & all fluids changed. Cleaned the IAC & TB. Installed a 07 WRX TMIC, MBC, Boost Gauge, re-piped the PCV system W/ 2- Catch can's, Snorkel & silencer delete W/ K&N.
Then onto some 05 STI Suspension
Slight Drop
Stripped the interior, dropped the headliner and sunroof assembly to re-seal. Shampooed nasty interior.
Found a custom 3" Rocket Rally exhaust off Patrick Richards street car, ordered a DP and then decided I might as well throw a TD04 on while im there, so I got one as well as a Perrin silicone Y-pipe & Tight radius 90 to replace my cheap E-bay Y-pipe & copper piping.
So that's my progress thus far. After I recover from my hernia surgery I will be installing the new Y-pipe, TD04, DP, HF Cat W/ Flex joint + Exhaust. FCD, Innovative LC-1 Wideband gauge. Walbro 255.
I also have new headlights and tailights to restore, new front and bumper and a 2.5 RS Hoodscoop to add as I fix the bodywork and proceed to cover it all in Satin Tank Green
Hope you enjoy and I thank everybody on this site for answering all my
