Shifter Linkage Spring
Noah
Post by Noah »
1995 Legacy 5 spd....
Did the clutch a week ago and realized that I am missing the little spring on the trans side of the shifter linkage
Item 20
Does anyone know if this is an issue??
Re: Shifter Linkage Spring
Welcome to the BBS.
You shifter knob will not center properly. There will be resistance one way, but will be loose and floppy the other way. It won't hurt anything, but I'd suggest replacing it.
Noah
Post by Noah »
Legacy777 wrote:Welcome to the BBS.
Sweet, figured this was the case. Thanks. Ill probably leave a junk yard and one will have put itself in my pocket haha
