pp6 install
pp6 install
So a buddy has a unused pp6 for sale with a rs harness. Any issue with installing this on my 94 tleg 22 t/ 25d dohc hybrid that I am not seeing? Should I just contact rallitek or.....?
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: pp6 install
What exactly do you mean by it has an RS harness? Was it just hooked up to an RS, or is there a patch harness that it was hooked up to that plugs in between the ECU & chassis ECU connectors?
There are people using these for fuel adjustments and to pull timing. My overall experience with the PP6 wasn't horrible, but it wasn't great either. Doug would be the one who has the most experience with it.
What are you looking to use the PP6 for? What mods do you have now and what are you looking to add?
