Will my old rally tires & wheels fit?
coffeeman885
Post by coffeeman885 »
I am picking up a 94 L wagon on Friday and will be starting my RallyX season in a few weeks. I used to race a Neon and thus I have Neon wheels with rally tires on them. I can get another season out of them and honestly don't have to money to buy new wheels and tires just yet. I was wondering if they would fit the Leggy. The wheels are 14X6 with a 35-45mm offset (best specs I have found so far, it is hard to find info on them.) I have Silverstone 505s on them.
Speed limits are like herpes - once you get them you will never be rid of them. - Jeremy Clarkson
'94 Legacy L Wagon "Bluella"
Re: Will my old rally tires & wheels fit?
Wel the info I found indicates that the Neon should also have a 5x100 bolt pattern. Assuming that's right, yes those wheels should work. The offset is a little low, but should still work.
What size tires do you have on them?
coffeeman885
They are 15-60-14 which close to 195-60-14.
Yeah, they may be close on the top near the strut, but if you test fit them and you have enough clearance there, you should be ok.
coffeeman885
Cool, I will have to test them out on Friday. I will post my results in case anybody else runs into these random-ass circumstances.
