GD lateral links on a 94 L wagon?
coffeeman885
Post by coffeeman885 »
I am trying to source the needed parts to put a rear sway on a 94 L and I have possibly ran across parts from a '04 WRX. I know that the mounts will work but will the lateral links and endlinks work too? I haven't been able to find a solid answer yet. I thought I had but apparently I was imagining that thread because I can't find it again.
Speed limits are like herpes - once you get them you will never be rid of them. - Jeremy Clarkson
'94 Legacy L Wagon "Bluella"
mesoslow6969
Re: GD lateral links on a 94 L wagon?
Post by mesoslow6969 »
i put 04 sti trailing arms on my legacy wagon. and also spc lateral links made for 02 wrxs. i'm sure they should work
Anti-Seize is my best friend.
coffeeman885
macipusy
Post by macipusy »
WRX lateral links will work
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
jamal
Vendor
Vendor
Post by jamal »
wrx sedan links are longer than your stock ones. will result in a wider rear track, excess camber, and possibly popping the axles out of the diff. The 02-07 stuff works as long as it's from a wagon or non-turbo.
macipusy
Post by macipusy »
Are you sure the sedan is not just wider in front? I have been running just the rear lateral links from a WRX sedan on my 91 SS for a few years and they were identical in length to the stock ones.
maciek puszynski
16 WRX | 6mt | fa20
The part #'s are different between sedan & wagon, and Whiteline has different part #'s for the sedan & wagon adjustable link kits, KTA108 for wagon vs. KTA109 for sedan.
You sure you got linkes from a sedan?
jamal
Vendor
Vendor
Post by jamal »
macipusy wrote:Are you sure the sedan is not just wider in front?
yes
macipusy
Post by macipusy »
It has been a few years since I got them. The junkyard was not the u-pull type of yard and the guy that pulled them said it was from a sedan.....maybe it was totalled and he didn't notice. I guess I got lucky with those.
maciek puszynski
16 WRX | 6mt | fa20
jamal
Vendor
Vendor
Post by jamal »
well, if it was a non turbo sedan they would be the same length. only the wrx sedan and sti got them.
IronMonkeyL255
Post by IronMonkeyL255 »
I am curious about this as well. I have the tranny and rear diff out of an '06 WRX sedan, and the rear axles fit perfectly while the fronts were too long because of the wider track. Is it a difference in the rear knuckles on the sedan, or how do they accomplish it?
Rio Red '91 Legacy SS
