Now two weeks later it's gotten way way worse. There's also a code stored in my ECU for the EGR system. The exhaust has gotten much louder and sounds like there's a hole in the pipe or muffler towards the rear. The car now jerks in all 5 gears violently if you try to accelerate. It's fine on cruising and once the engine is fully warmed up it goes away completely. It's quite dangerous if you forget about it because you won't be able to accelerate and merge into traffic at a fast enough pace.
Any idea where to start here? I haven't had time to check it out yet but I did push the EGR plunger open by hand a little bit and the rpms went down immediately which I read on another forum indicates the EGR passage is not clogged?
What do you think the relationship with the temperature of the engine is with this intermittent problem?
I miss the legacy.
