Swapping EJ22 an Automatic to a Manual
LegyC-LegyDO
Post by LegyC-LegyDO »
The Cars: 1992 Legacy L wagon w/EJ22 automatic transmission (125,000miles) AND 1992 Legacy L wagon w/EJ22 manual transmission (379,000m)
I want to swap the motor from the the automatic to the manual.
I suspect it will be easy, but will I need anything to make the engine from the automatic match up to the manual transmission?
ALSO: Both motors are mounted and running in the cars. Do I need anything else?
firstpost, thank you
rallyOre.
91 legacy turbo
Re: Swapping EJ22 an Automatic to a Manual
That is a direct swap. Are you going to swap the high mileage (kmage?) motor back into the auto? :D
LegyC-LegyDO
mike-tracy wrote:That is a direct swap. Are you going to swap the high mileage (kmage?) motor back into the auto? :D
No I am just going to take it apart, at least keep the block -if it checks out.
rallyOre.
91 legacy turbo
As Mike mentioned, you should be good to go with the swap. You'll need to swap over the flywheel from the old manual motor, but that's really all I can think of.
