Swapping EJ22 an Automatic to a Manual
Posted: Wed Mar 09, 2011 9:16 am
by LegyC-LegyDO
The Cars: 1992 Legacy L wagon w/EJ22 automatic transmission (125,000miles) AND 1992 Legacy L wagon w/EJ22 manual transmission (379,000m)
I want to swap the motor from the the automatic to the manual.
I suspect it will be easy, but will I need anything to make the engine from the automatic match up to the manual transmission?
ALSO: Both motors are mounted and running in the cars. Do I need anything else?
firstpost, thank you
Re: Swapping EJ22 an Automatic to a Manual
Posted: Wed Mar 09, 2011 9:36 am
by mike-tracy
That is a direct swap. Are you going to swap the high mileage (kmage?) motor back into the auto? :D
Posted: Wed Mar 09, 2011 10:05 am
by LegyC-LegyDO
mike-tracy wrote:That is a direct swap. Are you going to swap the high mileage (kmage?) motor back into the auto? :D
No I am just going to take it apart, at least keep the block -if it checks out.
Posted: Mon Mar 21, 2011 5:23 pm
As Mike mentioned, you should be good to go with the swap. You'll need to swap over the flywheel from the old manual motor, but that's really all I can think of.
