WRX turbo up-pipe bracket - got em
Got everything, thanks all
Need an up pipe bracket from an ej20g or EJ205 or whatever else fits an ej20g. The EJ22T one only fits on either the heads or the block, not both at the same time.
EJ22T (can't use mine):
EJ205 version:
Pics borrowed from WTDash's build.
Let me know the price, shipped, to Everett, Wa 98201
Re: Need PCV/Intake parts/WRX turbo bracket
i too need a set of brackets, anyone have part numbers?
zagarus
Post by zagarus »
#1 is pretty cheap to get new from the dealership. I had to get one and it was only $26. (pretty decent for an ergonomic part IMO).
#16 may not be that bad from the dealer also.
Prefer to support a member before I spend cash at the dealership, lol
Edited - I don't need part #1 any more.
jdmleggy97
Post by jdmleggy97 »
the bracket will work.. needs a little modding but it will work. trust me ive done it.. i think i had to grind an edge down..elongate the hole for the head and ad a 1/2" spacer...and it worked great!
jdmleggy97 wrote:the bracket will work.. needs a little modding but it will work. trust me ive done it.. i think i had to grind an edge down..elongate the hole for the head and ad a 1/2" spacer...and it worked great!
With what block/heads?
cj91legss wrote:i too need a set of brackets, anyone have part numbers?
For the two piece dealie:
14421AA021 for the big piece,
14427AA022 for the small one.
I might just order if no-one has em
Bump
kleinkid
Post by kleinkid »
What pieces do you still need?
kleinkid wrote:What pieces do you still need?
DOHC up-pipe bracket and turbo elbow.
kleinkid
Post by kleinkid »
Turbo elbow=pc. 16? I may have one.
#16, Yeah that would be great if you did. I have several, all cracked and held together by glue.
kleinkid
Post by kleinkid »
I'll look for it tomorrow and check condition.
Getting the intake elbow from Kleinkid, got the bracket.
